Fuel Issues
mlaxton
Florida
I have an 802A that runs my hunting camp, this weekend after running a heavy load on it to clean it out. The set shut down with a no fuel indicator. The gauge looked over full at first, then went to empty a few mins later. I opened the cap and the tank looked over full, the fuel level was up into the neck of the tank. I do run on Aux fuel out there, pulling from a drum. I reached my hand into the tank and felt the floats on the fuel level switch, both were moving freely. I pushed them down with my finger and they floated back up, I did this a few times. My tank is very clean the unit had 50hrs when I got it, now only 150hrs. I pulled the screws out of the sender, and when I lifted the sender I found that the bracket that holds the assembly had broke, see attached picture. I read a previous thread on here and I am a little confused. I guess my questions are.
1. Was the tank overfull? since the fuel level was up into neck.
2. Will a bad or broken sender cause a no fuel fault? I was told by someone only the liquid level switch can cause that, the senders only purpose is the level gauge on the panel.
3. Every time I search for a replacement sender # that I found on a thread here I come up empty, all I find is a substitute part from GMG, that claims to be "better" (is it??).
4. Does anyone know where to find this sender substitute other than GMG? As their prices are usually way higher than other sources.
5. Is it coincidence both the switch and sender went bad at the same time?
6. Also a good source for a NOS liquid level switch.
7. Also if someone has a link for a good well nut set up, I'm going to go ahead and do them while I'm here lol.
mlaxton
Florida
Sorry didn't see the other half but yes both well nuts are the same
Bulkhead fitting
Square profile Viton o-ring
Round Viton washer
For future reference.
Light in the Dark
5,923
MA
So the ultimate well nut upgrade fitting has a recessed groove to locate and seal the Viton ring. The fitting from McMaster has no such provision. For liquid holdback, you really need this groove.
Guyfang
23,985
Burgkunstadt, Germany
1. Was the tank overfull? since the fuel level was up into neck. (YES)
2. Will a bad or broken sender cause a no fuel fault? (NO) I was told by someone only the liquid level switch can cause that, (YES) the senders only purpose is the level gauge on the panel. (YES)
3. Every time I search for a replacement sender # that I found on a thread here I come up empty, all I find is a substitute part from GMG, that claims to be "better" (is it??). (Depends on who you ask. The ultimate well nut upgrade listed here in the forum seems to be 110% good. Never heard of it going bad or being a problem)
5. Is it coincidence both the switch and sender went bad at the same time? (Could be vibrations. Is the metal tank hold down on the set? And the plastic foot still on it.)
7. Also if someone has a link for a good well nut set up, I'm going to go ahead and do them while I'm here lol. (Look at the beginning of the Generator threads. There is a sticky there with info on the well nut.)
mlaxton
Florida
Thanks for the feedback, when I pulled the back cover, the hood down was loose and rattling, plastic intact. I did readjust it…
mlaxton
Florida
Are there any adjustments to make on the liquid level switch? Or they are set and do not move? I see some C clips on them in pictures, do they move or they are set in a groove? Hard to tell in a pic.
Guyfang
23,985
The original parts were adjustable in height, and one always needed to make sure the float was not touching anything. I often saw this type of fault/damage. I once found 3 floats in the tank, along with the one I was troubleshooting.
Ray70
5,862
West greenwich/RI
When you refer to C-Clips on the liquid level sender I believe you are talking about the J-shaped dual float assembly for the aux fuel pump and no fuel light, not the fuel gage sender.
The clips are in grooves and just keep the floats within their operational area, no adjustment can be made on that assembly, the sensors are magnetic within the tube.
On the fuel level sender I learned long ago to abandon the old technology and replace it with a marine style sender, which can be has as cheap as $28 240-33 ohm SAE 5 bolt flange magnetic liquid level sender.
Guyfang
23,985
I was hoping someone would jump in with that info. The army switches left a lot to be desired. When units were down range, they used any fuel they could get. JP-4 and Jet-A1 caused the floats to melt. There were other problems.
mlaxton
Florida
I purchased a marine one like this, 5.5”. Was 40 bucks. It looked the same as the one on GMG. Figured I give it a shot, sounds like it will work! Thanks.
uniquify
223
Sioux Falls, SD
My preferred fitting is the Ace Roto-Mold 10897, which is a 1/4" brass bulkhead fitting with a groove and a viton o-ring. I've got them from tank-depot.com in the past, but they're occasionally available on Amazon, too. Never had a tank leak since I started using these.
