ATC
- 0
- 16
- Roanoke, VA
First off, the fuel leak. Sorry I don't have a picture...it's cold and dark outside. There is a small...whatever it's called thing sticking out of the tube to the intake directly above the turbo. There is a plastic line that runs from it, across to the injectors. Fuel is leaking out of the end of that and right onto the turbo where is "burned" off (no flames, just smoke). It only leaks when running, not when the accessory switch is on.
Second. When I got this truck, the brake pedal felt awesome. The brakes would grab instantly (within the first 1/4" of travel), and dang near lock up around 7/8". Now, the pedal goes to within 2" from the floor before they start to grab. I can pump the pedal and get get more feel.
Now, I know part of it is my fault for not checking the brake fluid in a while...but I'm not sure how. The MC has a fitting on top with a hard line run from that to a "T" on the crossmember below it. I don't know if that's a breather or what. I was afraid to take it off for fear of getting air in the lines.
Any help would be great![Very Happy :grin: :grin:](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
