JesseJaymes
- 0
- 0
- Las Cruces, NM
Was inquiring if it would be possible to use a length of flexible steel fuel line for my fix. I need from the lift pump to the fuel filter. It was a hard, steel line that went up, over the engine, but under the intake.
I have been told this is just a low psi line, but I am concerned about the heat of the line, being over the engine.
Any other suggestions ?
I am going to have to butcher the original line in order to get the brass fitting off, as it was the original source of the headache and needs corrected. Been told to cut the end off and get a re-flaring tool and just slide a new fitting on and re-flare it.
