Fuel lines...
Anyone know off the top of their head, the supply and return fuel line sizes?
Also, what is the best soft "rubber" hose for it now?
Also also, what are we using for the injector returns? I used something recomended and it went soft.
m1008chevy
Canada,BC
I know the rubber line coming from the pump to the filter is 3/8 and 1/4 from the filter to the pump. Any rubber line rated for fuel should work no problem.
TechnoWeenie
1,815
Nova Laboratories, WA
Lines are different for gas and diesel. You can very easily find lines that will have their lining eaten away by the diesel....
Make sure you use diesel rated lines...
My local O'reilly auto, NAPA, etc has Goodyear diesel rated fuel line..
I found some Thermoid hose, made in USA, on the eBay. Bought 3/8 and 5/16. Pretty sure that will cover it. I had already put 1/4 inch in it at one point this summer. Still need to get the dual tanks working when it comes home.
