Fuel Pump Assemply - Hydraulic head Leak
mbouchard
Windham, New Hampshire
Hello all, new guy here and proud first time owner of a M35A2... I have been through the TM 9-2815-204-35 manual and it doesn't seem to have a rebuild section for the Fuel Pump Assemply - specifically the Hydraulic Head where all the fuel lines attach... I have a leak (slight spray) right where the four bolts hold the cylider (hydraulic head) to the rest of the Fuel Assebly Body. It's lightly misting / spraying out the slot where it looks like an area to pry (after you unbolt the four special purpose corner nuts... Can anyone direct / assist where to find an exploded assemply on the Fuel Pump Assemply so I can dis-assemble / replace / repair... Thanks, Mike - and I apologize for being new and not starting a new post correctly.
WillWagner
2,633
Monrovia, Ca.
Try TM 9-2910-226-34. It is here in the TM section. I think that will have what you need.
mbouchard
Thank you so much Sir. It's exactly what I was looking for / needed. I have to say, this site is such a great resource... I have been following it for a few months and finally just purchased my first M35A2 and joined the team - all the folks out here are so helpful... Again, Thank you Sir.
