Fuel Pump pops fuse
shannondeese
High Springs Fl
My Deuce has a fuel pump issue. I keep popping fuses, if I bypass the fuse it smokes the wires within about 1/4 second. I am getting 24 volts to the pump. When I measure resistance I am getting 4.6 ohms resistance between the feed wire and the cage the pump sits in. I am assuming that there is an internal short in my pump. Although it pumps very well just overheats the wires. So now I am stuck with a dilemma. Those of you running the external pump from summit, how does it work? Those that advocate putting the stock pump style back in tell me why. I have already modded a bunch of stuff on the Deuce so keeping it original isn't really necessary. But the best bang for the buck is. Thanks.
jamawieb
557
Ripley/TN
It's more than likely a short in the pump, I had the same problem. I went to e-*** and bought a replacement for $50.00. The guy is still selling them and it fixed the problem. Hope that helps, different fuel pumps have been discussed numerous times on here.
shannondeese
High Springs Fl
Thanks for the info about E-bay. I took the whole thing apart today and cleaned it all in the parts washer. Put it all back together with a new fuse and it's working again. Not sure for how long so I'll go ahead and order one from the guy on E-bay. Thanks again for the info.
