2deuce
- 147
- 63
- portland, oregon
Since the original pump is so expensive to replace, what mod have you guys done that works well? Did you keep it in the tank?
The engine may burn 8 or 10 gallons per hour, but some 30 gallons is circulated through the injection pump in an hour....maxim said:.....There seemed to be no problem with lack of fuel. The Carter was rated for 9-15 GPH and as I understand it the original was 9-12 GPH.
