Rustyshackelford
- 12
- 18
- Tucson AZ
Well I conquered the dreaded fuel pump job today. After reading many posts and PMing with a couple experts I felt I was armed with all the information I would need to make this job a success. That turned out to not be entirely true, there was one piece of information that could have saved me a HUGE headache. This info could very well be only true for my truck but I'm assuming everyone's trucks are just like mine.
Most fuel pump swap posts will lead you to believe that getting the bolts back in after swapping pumps is where all the trouble is. Now, this is true but, this info actually cost me 2.5 hours on my pump replacement. I was having a HELLUVA time getting the bolts to start on the threads when reassembling and I had just accepted that this was the way I should expect it to be. Having made that assumption I was trying over and over again with zero success and I wasn't pursuing any other avenues because of it. Fast forward 2.5 hours of me hanging upside down trying to thread in one bolt... I loosened the plate that holds the push rod in and changed it's alignment. This slight alignment adjustment allowed both the fuel pump bolts to thread right in and I was primed and running 15 min later.
Long story short, all the info I've read about the lift pump replacement on here was extrememly helpful except the omission of this tiny tid bit. Maybe it should go without saying and I'm just not a good enough mechanic to know it, but I thought I'd write it up for the next sucker.
To all who are about to do this job, please keep in mind that the plate under your pump needs to be aligned correctly before the two fuel pump bolts will find their homes.
God speed!
God speed!
