Fuel pump
Finn
Denmark
Hi
I have a quick question.
Is there and difference on the LD465-1 pump and the LD465-1A pump ?
Is comes of a LDS427-2 engine
And what i can read the lds427-2 engine was a turbo engine ?
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Are you asking about the fuel pump on the IP or the IP itself?
5here is not enough different on the pumps to worry about if your contemplating using in place of the one with the broken spring.
Finn
Denmark
Yes i plan to use the ld465-1 pump as a replacement for ld465-1a pump.
And i have had a hard time finding info on the lds-427-2 engine ... other then it’s an old obsolete engine ?
gimpyrobb
27,785
749
Cincy Ohio
Yes, the ldt 465 is the upgraded version of that motor. Many parts interchange but the bore is different and the stroke too I believe. I have a 427 ive taken apart and put some of the parts on my motor.
Elk1111
483
Las Cruces NM
The hydraulic head will be different on the the 427 pump if it is the type G so make sure you keep that.
