Fuel pump
Mrgior31513
81
Fontana, Ca
I actually bought that rebuild kit and cracked the pump body trying to get the pin out that the lever pivots on.
Oh, that sucks man. I looked up Jeep engines by Kaiser on Summit and came up with this for the I-6 230L:
I would highly recommend checking the specifics of your engine, but it's worth doing the engine search on that site for a broader range. I'm not sure if the cam is different on the military trucks, especially in relation to the mechanical pump lobe, but if you can't find anything else it seems like it's worth a shot on purchasing to compare and send back if one doesn't work.
Also works on the I-6 232*
