Fuel pump
1,174
Intank pump or IP boost pump?
saddamsnightmare
80
Abilene, Texas
September 3rd, 2008.
Memphis Equipment has them, expect $100.00 Core charge, fuel pump itself is around $300.00 and change
($400.00 some before core's sent back). I just got one, no squawks, truck primed and started right up.... Seem's these items rarely fail, but when they do and you should lose prime in the system..... life's not good. Old Red River Arsenal M35A2 mechanic says mine was only the second failure of this item he'd ever seen in 30+ years of repairing them.....
Cheers,
Kyle F. McGrogan
tjcouch
Tampa, FL
I just finished the in-line pump install, to replace the non-functioning in-tank pump.
Purchased from www.odiron.com
All neccessary parts included in the kit, tools needed: copper tube cutter, sandpaper, wrenches, solder, and heat shrink tubing.
Very easy install, works great!
JEOShea
Elgin, Illinois
Here is a photo of a new Pump and a Bracket. The clamp ring is designed with a toggle clamp. you can replace just the fuel pump. might think about a new gasket. The life expectancy of the pump by the way is about 2500-3000 hours. I know cause we life test them.
If this type of info is TMI, then I'll stop.
Jim
73m819
319
gainesville, ga.
will that pump fit a 809 series tank, is the bolt pattern the same for the pump mounting plate as the draw plate on the 809 series, can the pump be extended to the bottom of a 809 series tank???????????
