Fuel question
Sp0okfish
virginia
I got 150 gallons of diesel for free because it has been mixed with only 1-2 gallons of DEF, was wandering if it would hurt anything to burn it I have a water seperater fuel filter so I think I should be alright. Just want other people two cents to be safe.
1,172
Fluid, not fuel.
I was hoping the OP would confirm what he was talking about, rather than assume.
BIG_RED
Winnipeg, Manitoba
DEF has water in it:
"Diesel Exhaust Fluid, also called DEF, is a solution made up of purified water and 32.5 percent automotive-grade urea that is used as a carrying agent for the ammonia needed to reduce nitrogen oxide (NOx) emissions from vehicles into nitrogen, water and carbon dioxide (CO2)."
Quoted from: Diesel Exhaust Fluid | Facts About SCR
You do not want water in your fuel. Maybe if you got someone to run it through a centrifuge first, but then I don't know if that would get rid of the other chemicals (UREA) which are supposed to be fairly corrosive.
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
DEF=PEE
I would get a transfer pump and put a water seperator on that, rather than hope just the stock filter catches it. It might do it, but could leave you on the side of the road, at night, on a back road, needing to be somewhere quickly.2cents
Keith_J
1,316
Schertz TX
It settles out of diesel. It may form a scum with biodiesel so you would be best served to mix 1/2% two stroke oil into the diesel once decanted off the DEF.
The rest will be caught by the filters so drain them often into a clear jar to see if there is contamination.
