fuel return line on m35a2
86m1028
17
Murphy TEXAS
I just picked up an m35a2.
I have searched & searched but can someone show me a driverside pic of the engine compartment. I need the fuel return routing.
My truck is missing some of this.
Also does the fuel return tee off the filter housing ?
Thanks in advance.
Needle
Plano, TX
I see you are in 75094 (Murphy?).
After you see gimpyrobb photos, if you also need to look at one close up, pm me.
I am in 75024 (West Plano), although the truck is stored in Addison.
I also see you are parting out an M915A1. Wouldn't happen to have the muffler and stack available, and a headlight /dimmer switch would you?
86m1028
17
Murphy TEXAS
Yes, Im in Murphy.
Thank you for the offer to see yours. From the pic it looks like Addison Airport ?
I have the 915a1 down in south Texas. I will have to see if it still has the muffler, I know the stack is gone. I will also have to check on the dimmer switch. Pm me your # & I'll give you a call.
Ray
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
Sorry, brakes were out on the wrecker yesterday, didn't have a chance for the pics. I looked for that T on the secondary filter, it was gone. Anyone else have one for him?
86m1028
17
Murphy TEXAS
And some more.....and PM sent.
Thank you Thank you Thank you.
I jerry rigged it & even drove it today (YEAH).
Will fix correctly soon, now I need to fix the brakes & get guages.
Im hooked (on the duece). I will admit I bought this truck only for the winch.
BUT now plans changed after driving it. Im leaning toward bobing it...
First I'll replace whats missing & get it dependable. Then go from there.
S.S. has claimed a new victim ( and I have a grin from ear to ear)
Thanks again for the pics... this sight is GREAT & the people on here are even better.
Beyond Biodiesel
37
Prescott, AZ
I know that this is an old thread, and great photos, which help a lot, but my return lines are leaking, and the fittings sure are not normal. So, does anyone have a line of rebuilding the return lines, ie. hose type, dia, where to get the fittings, if needed.
RAYZER
59
sanford/florida
You can reuse the compression nuts, buy new ferrels, polly line inserts and dot approved polly line from napa or a truck parts supply.
Take a sample of the lines you are replacing to match them.
Hope this helps.
