Fuel Return Line Pressure?
msgjd
4,073
upstate ny
Nope. I spend more time than I should, but I read and even understand most of what I "like". I worked on military trucks back in the early 80's for a steel high-line company. Rebuilt from the ground up. Worked on trucks, then got into hydraulics. Not claiming to be the all knowing. Just somewhat experienced maybe?
... and for some weird reason i thought you were Staff Admin on here , making sure we all behaved ourselves ..
I stand corrected ! rofl
20,760
Well, I am on the "watch list" here.
I have occasionally had an opinion. And I have a bit of a political leaning as well. Sometimes I may have spoken "out of turn" according to the rules. I have a little juice in the TM section, but other than that I just tend to welcome everybody new and stuff like that...
msgjd
4,073
upstate ny
1. re-re-rebuild the fuel side of the pump, replace all the O-rings in the filter and test each fuel circuit for air using the transfer pump.
tore deeper into the cadaver PT pump today but not into the main body .. the suction gear pump can come off the main body in one easy piece , although a previous post above shows the gear pump "halved" to expose the gears
the gear pump's driveshaft pushes easily in/out of the main body , appears to be no tricky traps in doing so :p
