Fuel shutoff solenoid
nspctr1
San Antonio TX
I'm tracking fuel issues with my 998 with a 6.2. I have replaced the mechanical pump and now up to the injection pump. I believe the solenoid is bad so going to replace it. Are these available locally? special order? I've seen a few on EBay but not sure they can be trusted.
what should I expect to pay?
Mogman
8,864
Papalote, TX
If you hear it click the solenoid is not bad, it is more likely you have an IP problem.
turn the run switch to run plug and unplug the most forward wire on the IP and see if it clicks.
If it does click then sometimes you can pop the top off of the IP and see in the linkage is stuck.
This takes a special 5 pointed torx security bit, not the normal 6 point security bit and the top cover must be re-installed correctly or you could have a runaway.
Do you have good flow to the IP?
Have you removed the return line and see if you have fuel coming out of the return fitting?
Mogman
8,864
Papalote, TX
But if you are sure the solenoid is bad (measures open with an ohm meter) than here are a couple places I found that are reasonable.
nspctr1
San Antonio TX
Thanks!! there is 24V to the solenoid/pump and it doesn't click. With the lid off of the solenoid and the wires plugged in, if you move the start switch to start, should you something move? Is this something that may be stuck or frozen that can be cleaned and reset?
Milcommoguy
2,129
Rosamond, CA
Based on the way I understand the question...Is the cover grounded to the housing?
Needs a return circuit.
Just a little more info or picture to see what your doing 👀
Just woke up, CAMO
Mogman
8,864
Papalote, TX
Use an ohm meter to measure the resistance of the coil, if you apply 24V the coil should be magnetized, if it is out you can test that with a screw driver, it should pull the piece of metal in front of the coil.
You should also see an arc when you disconnect the jumper to the coil (that reverse EMF I talked about in another thread)
Retiredwarhorses
4,051
Brentwood, Calif
you have to ground the small ground jumper on the front left screw or it won’t work…the solenoid moves the fuel cutoff armatur, you should be able to move it yourself with almost no effort and it will spring back, absolutely any resistance and your truck will not start.
