Gunny65
- 7
- 18
- Bonners Ferry, idaho
My truck, M934A2, would not start this morning for the first time since I have owned it. I checked the fuel lines as suggested in other forum posts and found that the fuel line where the small filter is located is sucking air. You could hear it when I pushed on the filter and line. I looked in the TM and could not find the part number. I do not have a local company who can make me one, I have called around. Closest is 2 hours away. Here is a picture of the hose and filter. It is the hose that connects the metallic fuel line from the tank to the engine pump (where you prime the fuel system). I need the part number for both ends as the connectors sizes are different. It seems like the TM goes from the fuel pump system and injector lines to the tank lines and skips this area. At least I am sure I missed it but spent a good amount of time going back and forth. The long line is 12" and the short is 5". The only number I could get off the line itself is, 20511312 and that does not show up in the 24P TM. I think the other line has, 20511313. Both tags are super hard to read due to corrosion. Either way though, those part numbers do not show up in the TM. I found them online but it was incorporated with a bunch of other information I could not decipher. Ugh, frustrations... Anybody have a good part number or replacement part number?
