Fuel tank accessories for M934a2, duel tank setup
Gunny65
Bonners Ferry, idaho
I purchased a secondary tank for my truck. The sending unit is toast and all the other lines are cut. I also don't know specifically what parts I need to convert to dual tanks. Has anyone done this and know what parts I need to purchase? I found some parts but I am unsure so I am looking for assistance. I decided to use a civilian tank switch since the military ones tend to develop air leaks quicker than the civilian versions, in my experience. Anyway, suggestions on where to look or a list of some sort? Thanks.
74M35A2
315
Livonia, MI
I've used the Pollak dual fuel selector valve before with good success. It switches the suction, return, and fuel level sender signal all at the same time, to do exactly what you want. They are under $60 new and work great, they are OEM on Ford, GM, etc... Only concern would be the port size, as it is slightly smaller than what your truck is. But, I don't think it is smaller than the smallest diameter fitting on your truck, for example the ID of the fitting at the tank top, filter, or injection pump connection. Not sure, but it is one easy path to consider.
162tcat
45
Washington
I have a good fuel selector valve off a m931 so it would bolt right in your rig. Pm me if interested
