Fuel Tank Diverter Selector Valve
rtadams89
Phoenix, AZ
I have a Fuel Tank Diverter Selector Valve (NSN 2910-00-977-5495) from a 5 ton that is stuck in one position. Any recommendation on getting it unstuck? Are rebuild kits for this thing available or do I have to buy a replacement?
rtadams89
Phoenix, AZ
Took a look at that thread and disassembled my valve. Nothing seems wrong, even the o-rings look good. Not sure why it was stuck, but it moves freely now that I've put it back together, so hopefully it stays that way.
msgjd
3,192
upstate ny
being of a tapered brass design, it may have been tapped with a hammer at some point, or some other tool dropped on it, or even a boot heel. Or dropped on its head. Or easier still, with the lack of sulphur and other lubes in today's fuel, any taper valve can seize just by pushing down on it while turning it. Did that once and learned from it.
rtadams89
Phoenix, AZ
Well my issue returned and worse than ever now. To get the valve out this time I had to thread a slide hammer into the retaining bolt hole on the top of the valve handle and gently tap it up and out. Still looks clean, no scratches, no debris, no idea why it gets stuck. If I just drop the valve core into the body and let it settle in for a few seconds, it becomes stuck. Running my finger around the inside of the valve body I don't feel any burs or other issues.
I gotta wonder, how is this thing not expected to get stuck? Just like a drill/mill/lathe tooling with an R8/Jacobs/Morse taper, it seems like this thing would bind up by design.
Any ideas for how to keep this thing working or is it time for me to just replace it?
msgjd
3,192
upstate ny
They CAN bind up by design, just about all taper valves can. You certainly can try replacing it .. but as I mentioned prior, I wouldn't replace it until trying fuel lubricants . 7 of my trucks use these valves and have no problem with them sticking (except for the one mishap mentioned) However, they all have gotten a steady diet of lubes in the fuel since 2008 when low-sulphur became mandated here .. Did you try coating it with vegetable oil or dextron when you reassembled it? VO is heavy and would take awhile before diesel could completely wash it from the entire taper .. It also helps to apply a slight UPWARD pressure when operating these levers .. I wouldn't be surprised if there was ever a PM-Monthly entry about them
1,175
Have you cleaned/polished both sides? Is yours discolored at all?
rtadams89
Phoenix, AZ
I put Optilube XP with my diesel. I'll try cleaning it again with some brake klean and then coating with vegetable oil. I removed and polished the core; the outer portion is installed in a non-standard and hard to get to spot, so I have not polished it. Neither looked discolored or scratched.
1,175
I’ve used scotch-bride on a wooden dowel spun with a drill To clean the valve body still mounted in the truck. Also used carb and choke cleaner to devarnish.
