joesco
- 1
- 18
- Hampstead, NH
OK folks, after some down time, I started work today again on refurbishing my recently acquired MEP-002A. Today's tasks were to install one of the two Wix Spin-On Fuel Filter units and remove the fuel tank, to clean it.
Took about 15 minutes to install one of the two new Wix Filter units. The second unit hasn't arrived yet. Then I removed the fuel tank and could not believe what I found inside of it. I would swear it was filled a 1/3 of the way with moldy alien urine, but just wasn't able to id exactly.
As suggested by a couple of the experts on this forum (thank you), I emptied the tank found that the entire bottom of the tank had a very thick amount of sludge and possibly mold. I sprayed an entire can of carb cleaner inside of it, added about about a gallon of gas and dropped a length of light chain link in the tank and swished and swished and swished. I emptied it, but it was still a mess. So I put some acetone, along with another gallon of gas, swished and swished and I am now letting it sit overnight. I am not to encourage that I will be able to clean it.
My research on the forum tells me that the Aux pump feeds this tank. I was hoping I could just bypass the main fuel tank, but don't think so????? If I can't get the tank clean, any suggestions on what else I can do to clean it or find a replacement?
Thanks!
Thanks!
