Fuel water separator question
j_boucher
86
Virginia
Getting ready to do a fuel system filter change "first-time new owner" and had just a quick question does the knurled connector on the bottom of the fuel water separator turn to drain the fuel ? I only ask because it's very tight and I don't want to break it off accidentally. I looked in TMs and I found it mentions draining it but doesn't show the drain valve / unless I missed it
Adrok
174
33
Rochester NY
Petroleum ( fuel and oil ) floats. Opening the knurled connected drains the water. Just drain until definitive fuel runs out.
If it is not hand tight, be cautious using a tool. Plastic parts deform and crush easily. Especially when aged and exposed to petroleum products.
GeneralDisorder
4,539
Portland, OR
Operator level PMCS (After Operation):
1. Check fuel/water separator (Figure 4, Item 3) for leaks or damage. Notify Field Maintenance if leaks or damage are found.Class I leak exists.
Pass Fail
2. Check for presence of water in bowl (Figure 4, Item 4) of fuel/water separator (Figure 4, Item 3). If there is water in bowl, perform the following steps:
Pass Fail
a. Place suitable container under drain valve to collect fuel.
b. Turn knurled nut (Figure 4, Item 5) at bottom of fuel/water separator (Figure 4, Item 3) to the left to open drain valve.
c. Close drain valve by turning knurled nut (Figure 4, Item 5) to the right. Dispose of fuel in accordance with AR 200-1.
Review of the -10 manual is a good practice. More civilians with military vehicles should learn about the process.
Ronmar
6,931
Port angeles wa
Except that PMCS procedure skips a simple step...
Read the ring around the primer pump. you need to pump the water/fuel out the bottom of the filter bowl using the primer, when you open that drain.
if you open the bowl drain and it start sucking air into the bowl, that means your bypass flapper valve is leaking. the fuel in the line will flow back to the tank and suck air in thru that drain...
just did a video on maintaining that primer on my youtube channel username: Rronmar
j_boucher
86
Virginia
Thanks Ronmar , I will check it out tonight
