cucvrus
- 10,348
- 113
- Jonestown Pennsylvania
I was outside this afternoon and I thought well before winter breaks I want to add my scrap yard find radiator grille cover. Check it out. I picked up at work a couple years back. It is an Isuzu NPR diesel DEF regeneration unit heat shield. We removed it when we were mounting the body on the chassis and I kept it as a spare because we had damaged a few during the winter, Well this one was slightly damaged and I could not put it on a new $35K chassis so I came up with this plan. I wanted to do some more low budget removable add on's. I went to the hardware store and purchased 4 - 5/16" X 2 1/2" J bolts.($5.19) I did not drill any holes and damage or harm any CUCV parts in any way shape or form. I attached the under laying frame with the J bolts and then the insulated cover was attached to the frame with M8 bolts. I think it looks fine. I took it for a ride and it made a difference in the temperature of the heater. I have the canvas military front but with the light modifications I made it blocks my quad headlamp turn signals in the grille. And my other M1009 has the KC's mounted in the grille. So I thought why not. When it warms I will paint it and shot a few holes in it with the AR15 just for effect. What do you think. Be nice.
