Fuse block help (extra fuse)
Small Prepper
Gernantown, MD
Afternoon
Looking at fuse block and and just realized I found an extra fuse coming out of the spare port (see pictures) to marker lights (right side). The extra fuse block was hot and was partly melted. (With a 30 amp fuse in it) (Had head light on for about 20 minutes) Looks to me that someone installed a jumper for the head lights (previous owner). Any ideas where to start looking for problem? I have been reading the TM's. Here's I have what I have done so far: Replaced head lights, replace all runnig lights, replace signal switch, replace wiper switch. (This jumper was already in, when I bought the truck)
Any help would be helpful
Thanks S.P.
Warthog
231
OKC, OK
That diagram is not 100% accurate. Please read the updated fusebox layout in the CUCV Helpful Threads sticky.
Your melted fuse is the Headlight fuse which is also discussed in the CUCV Helpful Threads sticky
jplace1011
488
Santa Ana, CA
Hi Warthog, do you happen to have a link to the updated fusebox layout? Thank you for any help sir.
