Fuse block mystery
edpdx
75
Oregon
My turn signals and tail lights went out today. Checked the fuse- it was good. I pulled the 30amp fuse- just NW of the yellow flasher. Fuse was okay, but there was only one spade clamp present. It seems the slipped off the blade and went south into the block. If I can put a solid replacement back in I will, but I'm leaning towards routing extensions for those blades out the side and installing a HD 30 amp inline fuse. Has anyone taken their fuse block apart. I could use a few pointers on what to expect, so that I don't run into problems putting the halves back together later. Thanks in advance
