Fuse Box Warning!!!
mangus580
282
Western NY
Be very careful plugging things into the fusebox on the CUCV. I was changing my flasher today as everytime I put a trailer on, they blinked really fast. So while I was doing that.... I knocked the memory wire out for my stereo. I wasnt paying attention, and plugged it into what appears to be a 'voltmeter' port. Driving down the road afterwards, I started smelling something like hot electrical. :banghead: I glanced down at the radio and noticed it was alot brighter than normal.... It seems that the 'voltmeter' port in the fuse box is 24v!!!!!!!!!!!!!!!! :banghead: :banghead: :banghead:
Luckily, the radio seems to work fine still.... I just need to figure out where I had that wire stuffed before now.
Warren Lovell
SAN DIEGO, CA
Thanks what my problem was!!!
I plugged my cig lighter lead into the v-mtr slot (also now known as the 24V volt meter slot)
Man , that lighter xjust popped right out...It still fuctioned, but blew the 10 amp fuse.
Where to plug that wire now....
Warren
dilvoy
25
San Francisco, Ca.
You may be able to pop off the fuse panel assy from the body and find an empty terminal. The flat bars on one side are fused and the other side is not and there is not just one bar to choose from. one may be straight from the battery and the other may only power up with the key turmed to acc or while it is in the rum position. I know how the old mopars were and the CUCV's should be somewhat similar. You could tap off of this and make your own terminal for adding things just beside the fuse box. There is a negative terminal block on the left side just above the kick panel and behind the dash. It is perfect for attaching grounds in a neat way.
mangus580
282
Western NY
I know htere is a terminal there, just couldnt find it on the side of the road. Also I have noticed, the CUCV doesnt have the ACC position like most GM's.
tsmall07
Springfield, VA
Holy old topic!
I just learned this when installing my electric fuel pump. Hope I didn't hurt it... :roll: Figured I'd bump so the newer guys (like me) could benefit.
Are all the other fuses in the box 12v? What would be a good one to tap into if I want my pump to turn off with the key? Right now I just have it on a switch.
allrevup
Delaware
24v. source
That was the same 24v. fuse box terminal that I attached my first OEM am/fm radio on to, after I disconect it to replase the speakers. First the radio began to work intermitentlly then it fried a wire inside.
