Fuse
maddawg308
758
Appomattox, VA
My manual, 9-2320-361-20-1, says to use "4 amp" fuzes. What the difference between 2 amp and 4 amp? (if you answer 2 amps, I'm gonna break a beer bottle over your head next time I see you)
FormerNewMVGuy
10
stockton NJ
Well, I have put 3 amp slow blow fuse's in all 4 of my trucks, I seem to recall a thread about this a while back? I belive there was a PS article about stepping up from a 2 amp to a 3 amp fuse.
DanMartin
Hillsboro, Oregon (USA)
I had mine apart today to fix a leak in the fuse holder cover...it was completely full of fuel (bad tank gasket allowing fuel to slosh up into the cover through the wire bulkhead fitting I think). Anyways...it had a 2-1/2 amp fuse...guess the USAF just split the difference between the 2 and 3 amp changeover. :)
I need to replace my fuse because it is *full* of diesel fuel (yes...sloshing around in there...just think if it decided to get hot and blow!).
I'll be putting in another 2.5 amp if I can find it, but will go with 3 amp if I can't find them.
emmado22
147
Mid Hudson Valley NY
Anyone know how to calculate the amps the fuel pump draws?
2 amp, 2.5 amp, 3 amp, 4 amp... Who knows.. I do know that I bet A TON of trucks have BLOWN fuses in there......
bottleworks
Central NC
An electric motor is like a variable resistor. It's current draw will be based on the load of the motor. Measuring the winding's resistance and using Ohm's law would give incorrect real life results. Checking current draw with a multi meter in-line is the best way to go about it.
