Gama Goat axle and hub seals
Aussiecowboy
Echuca VIC, Australia
I need some help finding seals, or useable part numbers for the wheel bearing seals and the seal for the axle through the hub. My local bearing places have tried to match them with no success. I need the full 12 bearing seals and 6 axle seals. Can anyone help me out?
m38inmaine
46
Maine USA
Seal for the back of the hub 5330-00-410-2329/11640306
Bearing seals 5330-00-781-9639/11602255
5330-00-782-1444/11602142
Spindle seals 5330-00-781-9639/11602255
5330-00-143-8378/MS51001-23-2
First number is national stock number, followed by the part number. If you do a search of the NSN sometimes it will show the manufacturer and their part number. All my seals were fine so I have not looked for any, the only place I know of that might have them is Red River Parts in Texas. I have never seen a cross over listed for these seals, the problem is that the drive line of these is one off item.
Aussiecowboy
Many thanks for your help but I'm slightly confused now,(I'm only a very new goat owner). When I pulled the hubs the inner and outer bearing seals were the same part, the outer having an interference fit spacer ring. The above numbers suggest they are actually supposed to be different for back and front of hub?
Also I can only see one spindle seal in the drawings, why the two part numbers?
Again, thanks so much for your input, being in Aussie parts and info on goats is hard to find.
m38inmaine
46
Maine USA
11602255 is the outer wheel bearing seal, 11602142 is the seal on the inner bearing on the back side of the hub(large disk wheel bolts to), 11602255 is the spindle(what the wheel bearings slide over) seal the inner most seal, MS51001-23-2 is the seal for the back side of the spindle where the axle stub enters. The manual shows the inner and outer bearing seals are different. I am taking these part numbers and description out of TM 9-2320-242-34P dated April 1985, it's the parts manual.
