Gama Goat Crankcase capacity
Gamagoat1
Kiowa, Colorado
Tom,
I don't know why but all the books say 12 qts. also. If you put 12 qts. in the engine it will be pretty dam- full of oil. If you got a copy of the original Military Specs" back when Gamagoat.com was functioning, you'll notice that it calls for 9 qts.
The books are invaluable but they are full of errors. Got to be careful.
AMGeneral
115
Connelly Springs, NC
Bumping an old thread,I changed the oil in the Goat this week,and it took 12 quarts to bring it back to full with filter change.
The data plate in this Goat was also stamped 9 quarts,evidently that is without changing the filter?
BTW,I used NAPA Gold 1138 for the filter,worked great!
1958 M274
13
North GA
I don't know what engine oils y'all are using but here's a reminder that Detroit is very specific about not using multi viscosity (IE 15W40) in two strokes. According to documentation that I have read and what the Detroit dealer told me, for normal operating temperatures, they specify CF-2 rated straight 40W. Shell Rotella T1 40W meets this specification and is available at NAPA, Walmart, and Amazon.com...
http://www.epc.shell.com/Docs/GPCDO...Shell_Rotella_T1_40_(CF_CF-2)_(en-US)_TDS.pdf
AMGeneral
115
Thanks for the reminder Joe,I used Shell Rotella T1 30 wt CF-2 rated.
