wsucougarx
- 65
- 48
- Washington State
Hey guys, what have you done to make viewing your transfer case lube tube easier? Taking that doghouse off to make sure your lube pump is still primed is a pain. I did the Lucas Oil Stabilizer trick to help prevent the pump from losing prime. However, while trying to troubleshoot, I found my transfer case had lost it's prime. It resulted in a clunking sound after she was warmed up. Luckily, the damage was not permanent. After this experience, I will be on edge to make sure the transfer case is still getting lubed.
So, what have you done? I recall seeing a thread where someone extended a clear hose up through the doghouse.
