Please tell me more about these ways to lower the cab. How to keep cab deflated and the front squat system operation...Bob
this is in the operators manual…
The cab air suspension control is in the hydraulic control panel, turn it off to deflate the air springs.
the hydraulic suspension compression cylinders are on each side of the frame. Disconnect the chain plate from where they hang stored on the frame, remove the 2 locking pins from each cylinder.
use the hydraulic control panel and air op pump to fully extend the cylinders.
connect the chain plates to the pins on the axle, and use the hydraulic controls and pump to fully retract the hydraulic cylinders and re-install the pins to lock them in that position with the suspension fully compressed
disconnect the ctis controller connector and manually deflate the front tires to ~10 PSI…
