Garwood 20,000 lb winch. Need left hand roller guide for Fire Dept M542A Tanker
Celticlady
127
Arkansas
Garwood 20,000 lb winch. Need left hand roller guide bracket. The TM 55-2320-211-15-1 shows' the steel bracket as 7409804-1.
For those that followed my escapade on the cable tangle... Wait.. there's more...
Still cleaning up previous damage done to our winch.
When I was under the truck working the cable tangle I noticed the left hand roller guide was missing. The bracket below the top pin hole is sheared off. If you look at the original pictures i posted you can see its not there. I attached it here again.
This was not of my doing. Yes that is operator error. Someone (I had a discussion with the chief about that this morning. It got a bit heated) was winching at an extreme angle. They broke it off. No I don't have broken bits.
I need the left bracket assembly with the roller.
