Garwood 20k winch hydraulic motor specs
Markddhumvee
Glen NH
I have a 20,000lb Garwood winch with hydraulic motor and adapter. Could anyone please tell me the correct original Flow rate GPM and pressure PSI that these motors run on. I am trying to adapt the setup to run off a Cat loader with 3000 psi and 32 gpm and I imagine will need to regulate flow snd pressure.
Many thanks
cattlerepairman
3,337
NORTH (Canada)
The pump specs for the stock M35A3 hydraulic pump are
GPM 13 @1000RPM
Max RPM 3000
Inlet Port Sixe 1"
Rotation Counterclockwise
Max Pressure 3500PSI
shaft size 3/4 11 SPL
Outlet Port size 1" STR THD
The stock hydraulic motor is - Parker 113A-106-AS-0, 10.6 cid, SAE A-2 bolt pattern, shaft: 1 1/4" dia. with 5/16" keyway.
thanks to SEPHIROTHQ in this thread : https://www.steelsoldiers.com/threads/looking-for-m35a3-winch-parts.61413/page-3
By the way......: https://lmgtfy.com/?q=hydraulic+winch+flow+rate+pressure+M35A3+site:steelsoldiers.com
Black Ops
Colchester, VT
GPM 13 @1000RPM
Max RPM 3000
Inlet Port Sixe 1"
The m35a3 has a 10000 pound winch with a smaller motor than the 20000 pound winch.
The 20k winch motor is national stock number 4320-01-137-6293. Eaton 109-1094-006.
Markddhumvee
Glen NH
GPM 13 @1000RPM
Max RPM 3000
Inlet Port Sixe 1"
Very much appreciated thank you!
Markddhumvee
Glen NH
Thank you
So I will not need to regulate the glow rate just adjust the auxiliary hydraulic circuit down to 1850 psi ? The Cat hydraulic circuits can be adjusted for PSI thankfully!
Thank you for all the help!
Jbulach
2,176
Sunman Indiana
Yes, 1850 is max high end spec, be careful, best to shoot for 1750 for varying conditions, oil temp ect... if the winch wont pull it at 1750, you need to double line, or pay more cable out to get on the inner layers, or both. I run a gauge on mine by my controller so I can always tell where I’m at.
Markddhumvee
Glen NH
the motor, according to specs is rated at 3000psi, so I would guess the lower pressure set up is to avoid too much torque that would break something in the winch or the cable.
Unfortunately the spec plate on the motor is unreadable so not sure of make or model otherwise I could look up the specs and wirk around it. Seems reasonable to start out at 1800 psi and take it from there.
Here is a pic of the motor if snyone vould identify would be great!
davidb56
1,237
Bonners Ferry Idaho
S
See post #10 and look at the site. it "looks" exactly the same with the offset ports. it is exactly the same part # as Black Ops posted in post # 3. So If the splines/or keyway is the same as the one in your pic (cant see them) then you should be good to go. Personally, I would try to find a aftermarket one with the same exact spline and bolt flange, and live with a little bit different torque In/lbs and flow (rpms) for half the co$t. Good luck!
Markddhumvee
Glen NH
S
Thank you for some reason I missed clicking on that link! Thats the one!
