Barrman
- 1,730
- 113
- Giddings, Texas
I was prepping my winch for painting tonight and had to figure out a non destructive way to remove the handle. While going through my pile of pullers, I kept having to move the Pitman Arm puller out of the way. I finally decided to see if it would fit. It did, like it was made for it. A little off center, but it worked great. I did run out of travel before the really stuborn handle was off. A 3/8" drive 6mm short socket was perfect as a spacer to get the handle the rest of the way off.
This is just a normal auto Pitman Arm puller not modified in any way.
I wire brushed all the crud off the handle and got everything green like it should be.
Thought there might be somebody out there scratching their head about how to get this handle off. Hope this helps.
