Garwood Winch w/o cable Boyce Equipment good deal?
gunnersmate
United States
Boyce Equipment in Idaho is offering Garwood 10,000lb winches without the cable for $995, as apposed to with the cable for $2,500. It would seam to me the cable would be fairly easy to replace but why is there such a large price difference? I can't imagine that cable costs $1505. Is there something here I don't know?
ralph3162
Pleasanton / Texas
is it for just the winch or for bumper extension's and everything. I got my winch just the winch $200 then cost me $250 and change for 200' of cable. The whole setup with extension's, pto, linkage, cable, hook, and winch was only around $1800 for everything and I did the install. I did buy mine a piece at a time from a lot of different places and then when I had all the pieces I did the install.
rchalmers3
30
Irmo, South Carolina
There's nothing you don't already know about Boyce! I'd surmise they don't want to be bothered sourcing and installing cable!
Suggestion: If you are looking for a winch, just take it slow and troll the classified section of this forum from time to time. You will find that what you want will show up here if you are patient. And you will keep money circulating within our group!
Rick
ralph3162
Pleasanton / Texas
:ditto:
Rick
1,127
Cheapest I have sourced the correct wire rope for the deuce is $3.60 a foot. X200, plus the attaching hardware.
Doesn't add up to $1500, but it's a chunk.
rustystud
2,793
Woodinville, Washington
Gunnersmate, are you near any logging companies or heavy equipmentsuppliers ? You can usually pick-up a good deal buying there remnants. The cable comes on large spools, and logging companies and heavy equipment dealers will not always buy the whole spool. I have gotten real good deals this way for 1/2" and 5/8' and 3/4" wire rope.
18operator
1,855
Seville, Ohio
Yes, Rustystud is right, Also look into any crane companies that are near you. They always have something on hand, usually top of the line too!
rosco
Delta Junction, Alaska
The proper line for that winch is called 6x19, which refers to the strands. It has a fibre core, and is abrasion resistant. As much as 220' will fit on that drum.
