Gasket time
FreightTrain
Banned
2,730
13
Gadsden,Al
Got a gasket set on order from OD.Where can I buy or borrow a head bolt socket that WON'T BREAK!When I went to get going this morning there was a puddle about 12" in diameter under the truck of oil and another the same size of coolant under it.Was still dripping coolant but from the intake coolant thing on top and the upper radiator hose.
WillWagner
2,728
Monrovia, Ca.
FT, if you can't find one closer to you, i'll ship you the one I fabbed up. Let me know.
598
Karlsruhe, Germany
Just an additional thought: the oil stains on the right frame also can come from your crank case vent, which apparently has no rubber hose attached.
You might want to put a "slobber tube" on it, so it wont blow the oil fumes all over the frame and the starter.
Cheers,
Mark
