tankie88
- 4
- 18
- Redruth,Cornwall,England
Last year i had to drop my tranny to put in a new flexplate.Before i dropped it i had all the normal gear changing.Since then it changes up the gears quite fast.When you come to a hill it won't change down by its self i have to manually change down.If i hit the kick down it will change down but change back up after i let my foot off a bit.I've changed the modulater,cleaned out the vac pipes,new filter and oil.Anything else i should do????
