Gear indicator repair.
salt6
B'ville, OK
Since I was down with a bad back, I decided to repair the shift indicator. With a little research I found that part of the cluster was missing. So I replaced it with a few spare parts I had laying around.
Find out tomorrow if it will work.
CARNAC
The Envelope Please.
617
Corpus Christi, TX
So, is it still working?
I found out today, after working all day to correct dash and speedometer issues, that mine is broken. &^%(#))@*#&$&^#^@*#$*$()(#*&@@^#%!()!&#&@))@&#&#!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
And to reiterate !_)(#&@*#)$&$^%@&$^*&#(@)@*($&$(#)@__$&^^#)#+@*$^#)@_)@#!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Also replaced the speedometer cable and the speedometer still doesn't work. So I need to replace the speedo. The inside of the cable isn't turning.
BTW, the engineer that designed the shift indicator going to school. F'ing idiot.
