wsucougarx
- 65
- 48
- Washington State
From reading the forums it appears that the GEAR OIL to put in our deuces is GL-1. Please correct if I am wrong. I checked with every auto parts/supply store from Grays Harbor on up to Lacey looking for GL-1. The only gear oil on the shelf was GL-3 to GL-5. I asked several places about GL-1 and they just looked at me with a blank stares from NAPA and a tractor shop in Olympia. The guy behind the counter at Cut Rate Auto Parts said that GL-5 will be ok in the deuces but from what I have heard and read the additives in the GL5 are harmfull on the tranny and transfer case. Does anyone know where I can get GL-1 or can I use the gear oils. If it matters the truck I'm in the processing of getting was overhauled in 9/91.
I did contact Petit oil and they said they can special order GL-1 for about $100/5 gallons. Is this a bit much? I did check Home Depot and nothing
Please advise
Please advise
