Gear oil in front hub
Two Dogs
Conwy Valley, N.Wales, UK
Gear oil has leaked into the left hand front hub, not caused by over filling or blocked breather so I assume the inner axle seal has failed. I have read as many threads as possible and checked out the tech article on rebuilding front hubs. The parts book only shows 1 hub seal and the inner axle seal but posts mention inner and outer hub seals, are there two hub seals on the front or does this only apply to the rear?
jasonjc
289
Gravette Ar.
Yes the front has just the one seal on the back side of the hub. When you do it do both sides and put on a set of one pice boots back on. The boots go on ALOT easyer if every thing is really clean. If it were me I would also replace or rebuild the wheel cylinder when its all apart.
AceHigh
30
Princeton WV Lake City FL
That is really great advice.
Brock Steel
Lake Elisabeth Ca
The inner is a oil control seal, the outer hub seals are grease control seals. You will need a bearing puller and slide hammer. Make sure you ATV the inner seal good and grease the whole thing good. The inner hub nut is torked to 50 pounds and back of 1/8 inch, Outer 150.
