Gear Oil Info
bguy193
Farmersville,IL
I know that gear oil is a touchy subject around here, I just wanted to share some information that I have obtained. I have been searching for a good gear oil to suit the needs of the deuce and after about three days of discussing oil with many different oil company technicians I settled on one. I spoke with a technician from Valvoline that recommended their GL-5 MT-1 80W90 Gear oil. They still make an all mineral oil GL-1 also. I was told that they still make the old GL-1 mainly for the demand in being used in older tractors as well as MVs. He said that it works just as well as it always has but the newer GL-5 Is a higher quality gear lubricant and exceedes GL-1 performance. The lubricant we were discussing is formulated to be Yellow Metal Safe ( he added) and would be perfectly fine in the transmission, t-case, and differentials of the deuce. I am only making this post in the hopes that I may help someone else that is wondering about alternative solutions to GL-1. I will leave the Valvoline part numbers for both types of oils. I ordered mine through Oreilly's Auto Parts.
Valvoline # V V70044 : GL-1 TRA Gear Oil Five Gallon Pail
Valvoline # 838 : GL-5 MT-1 80W90 Gear Oil Five Gallon Pail
On another note I spoke with a Tech from Lucas Oil Products and found out that their oil additive is yellow metal safe as well.
jimm1009
71
Louisville, KY
NAPA also has their own brand of the GL-5 with MT additives as well in 5 gallon pails.
Thanks for sharing. More is better when it comes to information on our trucks.
jimm1009 :)
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
I'm not 100% sure, but I am almost positive that the NAPA brand of oil is Valvoline oil.
