Gearbox noice issue
knissen
Jutland, Denmark
Hi,
I have a Studebaker M35A1, w. sprag type transfer case.
Driving in high gear (4 & 5th), high range I have excessive gear noise.
Worst in 5th gear, and increasing w. rpm.
In low range no noise occur, even if I run it at max rpm in 5th.
I checked and changed gear oil on main gear box.
Any ideas?
1,127
Although it's difficult to diagnose, every deuce I've had that has had a noisy gearbox was the transmission.
If so, at a minimum it's a set of bearings (input/output).
knissen
Jutland, Denmark
I will check the transfer case next - my other 3 deuces are w. air engaged frontaxle. They do not have the same noise. (I also have a transfer case in stock, if the old sprag type should be the problem)
