Geared hub question
Vapor Trail
262
Kentucky
I’m not using CTIS and the seal parts were kind of expensive so I didn’t buy them. Mine are damaged so can I remove the ring clip and seal and leave them out or do they perform some other function? Thank you
Vapor Trail
262
Kentucky
Anyone? It's the tiny clip and seal inside the steering bracket that bolts onto the geared hub and fits over the spindle extension.
Mogman
8,704
Papalote, TX
There is no reason the seal is needed unless you are running CTIS, with the plug in the steering arm it's just like any other hub
