repofrank8
- 0
- 0
- bellefonte, pa
what would be better? running all stock except for 33s, Should I swap for a 700r4 or gears to 373s. any suggestions?
Do you have rubbing with those 33.3" tires on your 1008?
Not a chance, done a ton of them. You do need to shorten the rear driveshaft, and the Gear Vendor doesn't work in 4x4.Seems like you could install it in an hour.
I agree.I, myself, prefer keeping the lower gears and adding an OD gear.
I saw the M1028 he put the NV4500 with 35's on it. It WAS slick. I loved his mandrel bent exhaust system. Plus what a nice touch it was with a 'pineapple grenade' as the shifter for his NV4500 standard tranny.I just put 35's on M1028, it drives alot better on the highway, maybe 66 MPH, I just put a NV4500 and 35's on a different M1028 and It drives perfect. IMO. hope that sheds some light for you. thanks
