Gears Slipping?
hwyman722
I was driving my 5Ton (M813) this weekend and had some problems with it. As I was driving it felt as if was slipping a gear and the entire truck would shake for a second. It felt as it if was coming from the rear of the truck. I check at the differential fluid levels and was was a bit low but not bad. Has anyone had a problem similiar to this. I asked some other friend and they suggested either the clutch slipping or maybe the gears in one of the pumpkins were going bad. HELP.
hwyman722
Cool thanks for the information. I will try to adjust the clutch when I go back down to the lake and will let you know it that helps. If so I will replace it ASAP.
BKubu
1,123
Gaithersburg, MD
I once bought an M543A2 that had a really worn clutch. You could let the clutch out without the truck moving. It only started to move once you revved the motor. I drove that truck back home from an auction in DE. It was scary on hills as the truck would lose power when the clutch slipped. I feathered the pedal and was able to make it back.
