no gen 1 light with key on engine off. voltmeter never gets full. gen 2 charging properly. i have went through the TM's and wiring diagrams as best i can. the excite/ charging plug red wire has 12v key off. the brown has zero. with key on they both have 12v. main red wire has 12v. heater blower motor works and fuse is good. the steice connection has continuity all the way to pin "W" inside the cab. Gen1 light bulb is good.
using a known good alternator i still get nothing from #1 slot.
am i supposed to get anything from the tach wire?
only thing i haven't done is pull all the firewall connectors apart and see if they need cleaned because as far as i can tell it all tested good by the TM and verious threads on here about testing different things..
any and all help is welcome.
