GentleGiant
- 2
- 8
- Canada
Hello good people,
Just replaced the fuel pump and now it seems the ole truck has an electrical problem. The Gen 1 light is on continuously.
Having read some helpful threads on this, here is what I have done so far:
I cleaned all the wire terminals on the Gen 1 (except the one under the very secure little boot).
I tightened the belt.
I ran some tests:
Battery Voltage:
rear, truck off: 12.63 rear, truck running: 14.96
front, truck off: 13.05 front, truck running: 12.33 (I had just run the trickle charger overnight - that's why 13.05)
Alt 1 (drivers side):
big red wire, truck off: 13.05 volts
small red wire from plug: 13.05 volts
plug off, key off, exciter wire (brown wire on plug): nothing
plug off, key on, exciter wire: 12.02 volts (battery read 12.6 after the test: glow plugs took it down from the 13.05, I think)
The dashboard voltmeter sits exactly in the centre on the line between yellow and green.
Questions:
Thanks,
GentleGiant
I ran some tests:
Battery Voltage:
Questions:
- Can anyone confirm that it must be something in the alternator because the wire voltages seem to be correct?
- Could it also be a bad battery? That battery is pretty old - it came with the truck when I got it 10 years ago. I have load tested it and it shows just a teeny bit weak, but not terrible.
- If I don't use the lights, heater blower, etc... is it OK (safe) to drive the truck with Gen 1 not working, as long as I don't turn it off and maybe carry my battery charger along with me? I'm going to fix this... but got some errands to do.
Thanks,
GentleGiant
