gen 1 light brighter
trooper632
Utopia, TX
Just got the generator rebuilt and after it starts gen 1 light stays on but dim, as you accelerate it gets brighter and stays bright while driving. then at adle its dim. what gives.
1,177
CCKW's have a gen 1 light?
edit, I moved this to the cucv forum(was posted in the cckw forum)
ida34
33
Dexter, MI
Only when it has had a really hard collision with a cucv. If this is a cucv you should have two alternators. Did you have the driver's side or the passenger's side rebuilt? The driver's side is the one that shows up as Gen1.
trooper632
Utopia, TX
It was the drivers side that was rebuilt, I had a coulpe rebuilt now that u mention it. Does it matter if you put one on the opposite.
4bogginchevys
rathdrum idaho
on a related topic I was curious if anyone knows why the military chooses to call them "gen 1 gen 2" when they are altenators? To my knowledge chevy hasn't used a generator since the 60's
1,177
Please don't try to be logical when talking military terms!
ragedracer
Phoenix, AZ
Yes, it matters. One can go on the other, but not vice versa. I can't remember off the top of my head which way though. (EDIT: This only applies if you're replacing one of the alternators with a civilian unit - if the one they rebuilt is isolated ground, it doesn't matter which side it's on) Obviously though, if your gen light is on, something is wrong.
Springer604
vancouver canada
im having the same problem cleaned every connection i could find all fuses and the sockets cleaned took dash cluster outand cleaned it,every ground scratched clean i took alt 1 apart changed diode tri as per anouther thread but still no luck only thing i can find wrong is when runnig alt 1 only puts out 14.60 to 14.55 while alt 2 puts out 14.7 is this the rectifier or brushes going bad? (hind site is i should have just put new every thing but im cheap) and yes i have new batteries new belts and truck only has 5500 og miles its a 1031 and im stuck next is rebuild the alt 1 ??????? please help!!!!!!light is bright at first gets dim turn fan on light gets 75% headlights plus fan 90% bright turn signals pulsate light with blinkin
