Gen 2 dim at idle, sometimes slow cranking, sometimes not.
121
Metairie, LA
With my m1009 at idle, I have 14.4 at gen 1, which I just rebuilt, and 30 at gen two( Iam guessing that this is thier combined number, I was testing by holding onto the red wire and ground.) At Idle my front battery shows 14.4, my rear 14.7. My gen1 bulb was out for a couple days, so I replaced it, it lights up now at start, no problem. My gen 2 bulb is dimly lit at idle, then dissapears with rpm. I have another rebuild kit. Is it time for gen2 rebuild? My instrument panel is on the to do list as well. What is my best course of action? Here are some possible contributing factors. The burnt out gen1 bulb, I have done the doghead mod already, and have throughly gone over the fuel system, and installed a Racor spin on. I also just cleaned and replaced my heater and 24v fuses. I recently installed a new heater core. My voltmeter is right on the mark in the green after the glow plugs cycle, in yellow right after starting.
Barrman
1,730
Giddings, Texas
So, your problem is the slow starting?
Has your starter been rebuilt or replaced in the past 2 years? If not, then it is probably the reason for the slow spinning rpm. Your voltage numbers seem to be right on. How old are the batteries and what do they do with a load tester?
121
Metairie, LA
The batteries show just over 13v each with the engine off. I have only been driving the truck for about three months though, I am unsure of the age of the starter. I will take the rear battery to be tested/charged. The slow spinning seems related to a lack of juice, but I could be dead wrong. Certainly some elec. troubleshooting is in order, I just want to make the vehicle reliable as possible as soon as possible. batteries are the mil spec ones, dated 2006, pretty old.
Barrman
1,730
Giddings, Texas
Check the batteries and then check the starter after you fire up the truck. Put your hand on it. A very warm or hot starter is a sure sign of needing a new one.
121
Metairie, LA
Whatever the root of my problem, I seem to have "accidentally" fixed it, Tightening belts- changing bulbs etc???? I pulled the rear battery to have it tested, 13v & 100% charge, so I guess alll is well. I believe one of my battery terminals may have been a bit loose. Perhaps this was the culprit. Whatever the case, I Thank You. No change in temp. on the starter.
