Hi all and I hope you are having an enjoyable Thanksgiving weekend. The weather here is warm for this time of year so its nice to get out and work on the truck.
I read through what I could find on various gen 2 posts here, but I have not found the solution to my problem of the gen 2 light never coming on. The truck seems to function fine except for this issue, and here is what I have done so far:
-Gen 2 bulb behind the dash is replaced with a confirmed good one.
-All fuses are good in the cab are good
-fusible links were inspected and seem fine.
-New relay installed
-Both alternators are charging both batteries.
-Replaced the belt on the passenger side alternator (Gen 2)
-Voltage gauge was shot and has been replaced and voltage goes from around 24V while glow plugs heat up on startup to around 28-29V when running.
Notes/questions:
The truck starts and runs fine, but it bothers me that the light is not functional.
The gen 1 alternator looks new, but the gen 2 looks original.
Do you think an alternator rebuild required to address this?
Could the diode before the relay be the issue?
My next steps:
Trace the orange wire from the fuse box to the instrument panel, and trace the wires form the relay to the bulb to check for broken wire.
Put a multi meter on the relay leads as well as the light bulb socket contacts.
Find the diode and test it as well.
Let me know if any of my next steps are a waste of time. I am running out of ideas and feeling like I am chasing my tail a bit. Any help is appreciated.
Thanks,
Nate
Notes/questions:
My next steps:
Thanks,
Nate
