Dispatcher7
- 24
- 8
- Pittstown, NY
GEN 2 is not charging Battery 2. So I began trouble shooting with help for the TM's on this site. Here is what I have found so far:
GEN 2 exciter plug, red wire has 24v, brown wire nothing.
Volt Meter was not working. Removed from dash and found the resistor on the back of the Volt Meter was missing. Replaced the volt meter with a working one.
Fuse 12 which should be 10 amp was 20 amp and blown. Replaced with a good 10 amp fuse. Now the volt meter shows voltage when the key is on, GEN 2 light still does not come on and no exciter voltage.
Changed the GEN 2 bulb with a good bulb, still does not come on and still no exciter voltage.
So I started reading more on here trying to locate the GEN 2 relay, which I believe I have found, but it only has 12 volts to it. One of two relays next to the starter relay.
With the key ON:
The Volt Meter has 24v.
Fuse 12 has 24v, all fuses are good.
GEN 2 bulb is good, but never comes on.
What I believe is the GEN 2 Diode has .8v on each side of it. It was taped up to the wire harness, top of dash near the Volt Meter. A picture on this site said it was the GEN 2 Diode.
Only one wire going to the 6 leg spider near the park break?
Thanks.
EDIT:
Right after posting this I found in the CUCV Switches, Diodes, Relays thread, post #15 that these are the GEN 2 and Voltmeter Relays. "The GEN2 and Voltmeter relay are next to the starter relay. They look the same and have the same wire colors. You will have to test to find the correct one."
I don't see a Voltmeter relay in any of the schematics. And both of these relays only have 12v going to them.
See, I am trying to figure this out without begging for help. But I am still lost.
Thanks again.
With the key ON:
Thanks.
EDIT:
Thanks again.
