Gen lights flashing randomly, 1 or 2, never both
Skinny
488
Portsmouth, NH
Background on the system:
I have replaced both batteries a few months ago. I rebuilt both alternators with complete CUCV electric kits about two months ago along with new underdash relays. Brand new belts which are tight, all terminals cleaned up, the whole system is functioning great.
I noticed this weekend that my charge lights are flashing randomly. I was driving yesterday and Gen2 would blip on for less than a second (really have to focus to see it) completely randomly. Then this morning, Gen1 would do the same. Tonight Gen2 was doing it. Both Gen lights wouldn't do it at the same time...very strange.
I checked charging system voltages. Gen1 fluctuates every few seconds from 14.5v to 15v, Gen2 stays right at 14.4v
Would this be the regulators going bad? Maybe I got a bad batch or something. I don't care, I will tear them down and replace them either way. This just seems like a very strange issue. Other than the slight voltage fluctuation and the light randomly coming on, system operates great. Both Gen lights illuminate KOEO, go out as soon as the engine starts after blipping the throttle.
Anyone have any input on this?
1,176
Is your idle low?
Barrman
1,734
Giddings, Texas
Have you pulled and cleaned all the fuses, relays, plugs under the hood, big plug passing through the firewall and all the terminals? What is your volt meter doing when the lights flicker?
Skinny
488
Portsmouth, NH
My idle is slightly lower when I replaced my IP. my Gen2 is very dim if idling in gear but goes off as soon as I take it out of gear or touch the throttle. I'm assuming this is just due to low engine rpms as it did that before the rebuild as well.
This problem occurs while driving down the road. Voltmeter stays in its normal position right between the red and green colors on the line. It doesn't move.
Both alternators have new regulator pigtails with solderless heat shrink connectors. Big plug on the firewall is clean, all connections are good.
